Hello Everyone, this is my first post. I have a SWR Strawberry Blonde II acoustic amp, and most of the schematics. I suspect the Pwr Amp PCB, but the schematic I received from Fender appears to be for the original Strawberry Blonde amp, NOT the Strawberry Blonde II. As soon as power is applied, This really loud, constant hum starts. It has a cyclical popping occurring, also. Kind of like a consistent tremolo pulsing. I don't leave it on for more than ~ 20 seconds at a time, 'cause I don't want to blow a fuse. I've tried all of the standard visual inspections. Disconnected the Input PCB, no difference. Having a blank 1/4' jack plugged into the input has no effect. I removed the Power & Pre PCBs and checked for any obvious signs of burning, or burnt components. This PCB has four large discreet diodes to make the Bridge Rectifier, and there is present +15V and -14.7V. I haven't checked the rails for signs of AC voltage yet. I have a DVM, but no O-scope.
Does anyone have access to the newer Power PCB schematic? It has a 2004 Fender Musical Instruments label on the component side, and is cream colored. The circuit side is green with solder resist and has this part # 0061560000 Rev. 6.
Have any of you ever worked on this amp before? Any suggestions if I can't find an accurate schematic?
I removed the two big filter caps, 3300uf @ 63V, to check for shorts. I'm not saying that I don't suspect them anymore, just that they're not shorted. I resoldered them, along with what I think are the two + & - 15V zeners. There is slight scorching on the PCB at these zener diode components. I also checked the values of the two cement power resistors on these supply voltages, and they still measure as expected. Also resoldered them, and some of the other major components, but I did not resolder the whole PCB. I did resolder the whole, small speaker output PCB.
Any help would be greatly appreciated!
Thanks, Nick
Thanks, Nick
