Hello All,
Need help troubleshooting a old Bedrock 600 amp that blows fuses on startup. I've checked the diodes and replaced the filter caps but it still seems to be drawing alot of current through a light bulb limiter. If I pull the power tubes the light bulb dims noticeably. With the power tubes out, (a quartet of EL 84s) the B+ is 425 volts, when they are in it drops to 295 volts. Also the max bias voltage is -14V, is this too low? I've checked the bias and the lowest I can get the EL84s to idle at is 12 watts. If I leave the power tubes in and pull the phase splitter tube the lightbulb also stays dim.
The voltages on the el84s are grid -14, plate 294 V, screen 292.
This amp is a old pc board amp so I don't want to get into wholesale part substitution because every time I look at it some component, trace or wire seems to break, therefore I'm asking the experts here for some advice on troubleshooting it.
I have some rough schematics I can post with the voltages I've measured on it. I also read positive voltages on the grids of v2 in the preamp which I think is set up as a cathode follower and in V3 which is a ltp.
V2 voltages are (pin 1) 296 V, (pin 2) 0V, (pin 3) 1V, (pin 6) 255V, (pin 7) 175V, (pin 8) 176V.
The voltages on the V3 phase splitter tube are (pin 1) 200 V, (pin 2) 14V, (pin 3) 24V, (pin 6) 231V, (pin 7) 15V, (pin 8) 24V.
The grid voltages are lower than the cathode voltage so I guess that is ok?
Thanks in advance for any advice!
