Hello Folks
Wanted to get your thoughts on this Mesa I have. The owner claims the amp sounds great and then becomes "thin" sounding after say an hour of playing. That is the only descriptor he gives, no other issues, pops, crackles, hum, etc.
So I ran the amp for over an hour, monitored preamp and power tube voltages and everything remained stable with no change in sound at all (still sounds really good).
I hate to give it back and say nothing is wrong or just recommend new tubes when it appears the current ones are ok. The only issue is the power tubes are biased hot (EL84 fixed bias) at 32 m/a but there is no red plating or even excessive heat after an hour of loud playing.
Also I checked all pots for the notorious loose back plate issue and all are solid/tight.
So what you seasoned pros do at this point?
Thanks for the advice.
schematic links for Mesa Subway Rocket:
Schematics: Mesa Boogie: Index : Updated June 7, 2012
