Hey all,
I fixed a chap's HR Deluxe a few months back...it came to me not working at all. It took me a few minutes to realize that the PT was bad, open primary....weird. I rarely see amps with an open primary winding...no biggy. I bought another from CE Distributors and popped it in...
The amp came to life and sounded great except that the power tubes were a bit rattley so I replaced them and rebiased the amp. It sounded great and looked great on the scope. I left the amp on for a while while I did other stuff so I could touch up the bias if it had drifted.
I went back to the amp about a 1/2 hour later and it was dead. Suspecting that maybe I'd blown a weak fuse, I checked the mains fuse and it was fine. I started checking things out and found the primary open again!
The amp has been sitting on the shelf since then as the owner is out on tour and didn't need the amp back for a while. He's coming back in about a month and I suspect he'll want his amp back, preferably fixed .
I am assuming that the thermal fuse has popped inside both PT's. I plan on ripping one apart in the next few days to confirm this. Assuming it is the PT thermal fuse, there must be a circuit that is pulling too much current stressing and overheating the PT.
When I powered up the amp after replacing the PT, I had it plugged into the light bulb current limit set up and didn't notice anything unusual. I actually left it that way for about 5 minutes before I switched over to full mains so I could set bias for the new tubes.
Before I replace the transformer (again!), I need to make sure I figure out what is pulling excessive current. Does anyone know what I should expect for quiescent current in the different circuits (HT, Bias, filament, etc)?
If not, I have a friend that has an HRDLX that I could borrow for an evening and take current readings. Unfortunately, he lives about two and a half hours away.
The other thing I could do is bypass the internal thermal fuse just for testing purposes and see if I can see what seems to be pulling too much current.
Any ideas you guys can throw at me would help...Barking up the wrong tree is no fun. I know there are threads on here about open PT thermal fuses but there doesn't seem to be any follow up as to what was found to have caused it.
Thanks for any and all help and suggestions.
Edit: I found these on a website...I guess it's a place to start:
Primary supply
120 VAC @ 60 Hz (Black - White)
Secondary
#1 (Red - Red)
495 VDC unloaded
440 VDC @ 65.7 mA DC
388 VDC @ 200 mA DC
#2 (Brown - Brown)
-53.6 VDC @ 1.58 mA DC
#3 (Green - Green)
6.6 VAC @ 3.75 mA AC
Primary supply
Secondary
#1 (Red - Red)
495 VDC unloaded
388 VDC @ 200 mA DC
#2 (Brown - Brown)
#3 (Green - Green)
