I've got a Peavey XXX head that the owner says after about 20 mins "the distortion doesn't sound so good". Never looses volume, just doesn't sound as good distortion wise. And he put new EL34 power tubes in it. Never listened to it on the clean channel cause he doesn't use it. I fired it up and played for about an hour. It didn't sound too bad to me but I'm not familiar with what they are supposed to sound like. I did the think that even the clean channel was not all that great.
Started checking voltages and the power section seemed to be good. The only red flag I see is on the power tubes, only one of them have high voltage on the screen. they all have like 2 - 5 Vdc on them except one that has voltage close to the plate. And those screen resistors are those 5W ceramics.
I was going to start with replacing those and see if that returns the high screen voltage seeing as how they all have high voltage on the supply side, just not the tube side. Just looking for a consensus that I'm on the right track and not overlooking something else obvious.
thanks in advance.
thanks in advance.
