I have a hum problem.
Basically a Fender BF preamp...into a LTP Inverter...into a 2x 6K6 power amp.
The hum is effected by the volume pot, and it goes away if I pull V1.
If I set my meter to Hz, and out it on the speaker jack, it says 120.....but it does not say 120 anywhere further back.
So that is the problem I need to find.
My meter question is...when you have the meter on Hz...are the probes in series with the meter.?
If I try to get a Hertz reading off the positive lug of the preamp power supply cap (red probe on cap+, black probe at chassis ground) the whole amp goes dead quiet.
I do not think that is what happens if I try to get a Hertz reading from the other PS Caps.
Thank You
Thank You
