Just a suggestion: reread what I posted & take a few carefull voltage measurements.
Consider first that the circuit is a Class AB type.
In pure Class B the output transistors are 'Off".
This can lead to crossover distortion, so the outputs have a small voltage on there bases to put them into Class AB, thereby eliminating the xover distortion.
To understand the circuit, you have to know how an NPN ans a PNP transistor work.(in this circuit)
Basically the collectors get tied to a high voltage.
The base of an NPN, when at a low voltage, is 'Off'.
The base on an NPN needs about .560 Vdc to 'turn on'.
A PNP base is normally a high voltage to be considered 'off'.
Lower the base by .560 Vdc & it starts to turn 'On'
TR5 & 6 are biased a tad different.
