This amp has, on the limiter, 38vdc, no speaker attached. I lifted several components to check for shorts and have found none. They are Q18, Q15, D35 & 36 and C53. These look good. But there is the 38 volts on the output.
I've tried the in circuit diode test on the, I think all of the other transistors and none appear to be shorted.
So the question I have, could it be that the output transistors shorted when voltage is applied?
