When the volume is turned past about 2, what sounds like a 60hz powerful farting oscillation takes over and swamps out everything.
>When the output tubes are taken out, it doesn’t happen. The signals at the grids look normal.
>It has been extensively re-wired with new parts, both capacitors and resistors, but although a bit sloppy, seems to be done accurately according to the schematic, which also seems to be accurate.
>I tried swapping the output transformer leads to the plates of the output tubes, only to be greeted by a horrible howl from Hell.
>I suspect the main filter cap is compromised, but cannot confirm it with a cap checker. It’s a JJ multi-section 40/20/20/20 @ 500 volts rating. The power supply puts out about 585 volts. It reads good as far as capacitance on my 878A LCR meter. The “D” and “Q” readings are normal. Is it possible it’s breaking down just enough to belch out this horrible low frequency noise and then look normal to a cap checker? It’s totally dis-connected at present, and I don’t really want to hook it back up. I suppose I’ll have to re-do the power supply filter section and try it again, but I’d appreciate any feedback I can get on this. Thanks!
