SWR Workingman's 15 Combo humming...
  • SWR Workingman's 15 Combo humming...
    Lowish output, distorted/crackling, and hum.... +HV is 48V, -HV is -74V. this doesn't seem right...does it? if not, what could be causing this? thanks for your help...
    http://music-electronics-forum.com/a...-amp-rev-1.pdf
    Check the AC content on the +HV rail. I suspect, you likely have a filter capacitor that is either defective or has broken loose from the circuit board. You should probably also unplug the speaker until you get it sorted.
      Originally posted by the dude View Post
      check the ac content on the +hv rail. I suspect, you likely have a filter capacitor that is either defective or has broken loose from the circuit board. You should probably also unplug the speaker until you get it sorted.
      24vac @ +hv....0vac @ -hv
        C1 is not working. It is either defective, or has come loose. Check the solder joints on this cap. Give it a good wiggle. Sometimes hairline solder cracks are hard to see.
          solder joints are good....cap must be bad. thanks!
            If you don't have a cap to sub, you can swap C1 and C2 and see if your AC problem goes to the -HV side. Might be good to verify before you order parts.
              found 2 x 6800uF/63V caps locally...installed them, and all is good. thanks again!
