Hum Problem in a 69 Bandmaster Reverb
Originally posted by SBax View PostWell, that was weird. The OT secondary was loose at the speaker jack. Soldered back and no hum.
I had inspected the doghouse at the same time and replaced the cover but spun it around the other way. The foam strip pushed down a loose connection that was causing the hum. As I opened the doghouse cover again, the hum returned. That was fixed with a re-solder and now the real cause for the hum was fixed.
