Trying to troubleshoot a Marshall AVT-50H guitar amp
No sound from headphones or outputs, no effects return etc
the tube is glowing and I've also swap tested the tube with another AVT-50 amp
The main large board I have ordered and replaced along with the other board with IC1 chip but the parts sent were different, not AVT50 but AVT50X and AVT275 the board sent is slightly bigger than the original (the smaller one on the heatsink that is) just wondering if these are actually interchangeable?
The amp is powering on, the fan is running, when I put the headphones in I can hear no noise at all.
I've checked all connectors time and time again, but yet no sound at all, what else can I check? I do have the right boards installed also for the AVT-50H ? the boards have AVT-50X on them as you can see in the attached image.
