I'm having some issues biasing my Carvin V3M, and I was wondering if anybody could help me troubleshoot:
The tl;dr of biasing a Carvin amp is that you hook up a multimeter across the standby switch and read the mA while you adjust a bias control pot on the board.
I've got my meter hooked up to the switch, have the amp on and in standby, speaker plugged in, amp at 50w, and all volumes at 0.
The reading I'm supposed to be getting is ~80mA, but the reading I'm actually getting is ~40mA. Stranger still, when I adjust the bias pot, I see no change in this reading.
I tried putting the original set of tubes back in and got the same reading, so I don't think the problem is bad tubes. I've also confirmed that the meter gives good readings with a AA and 9v battery. The only thing I can think of is that I must be missing some step or instructions somewhere that I can't see.
Does anybody have any suggestions for things to try?
Footnote: Here are Carvin's detailed instructions for biasing this amp, which I've been following: http://www.carvinservice.com/crg/faq...m_and_v3mc.pdf
I can also get pictures if it would help.
