Hello,
I have a Bogner Shiva on the bench that is blowing the main fuse. Upon replacement of the main fuse, the removal of the power tubes, and gradual AC applied via a variac, all appears well. The amp pulls 500mA idle (off of standby), the bias supply is consistent, plates are consistent at 528V and the amp will run seemingly without issue. I also checked the screen grid and control grid resistors and both meter properly.
Guessing that perhaps the Svetlana EL34s had some sort of failure only present under high voltage/high current (they tested fine for shorts and emission in a tester), I replaced the pair with a set of JJ E34Ls I had lying around. I made certain to lower the bias voltage to the lowest setting (roughly -54V vs. the -47V it was running stock) before slotting in new tubes. The same behavior was exhibited: it idled for ~1 minute at 800mA before increasing rapidly. I managed to cut the power before a fuse blew, but the behavior happens consistently when power tubes are inserted.
Unfortunately, from what I've read online Bogner refuses to supply schematics. This model has a traditional power transformer - from what Google Images showed me a SMPS was later added to certain Shiva models. Any help in troubleshooting this problem would be greatly appreciated.
Thanks,
Chris
Thanks,
Chris
