I got a perfectly good working David Eden WT800 in the shop that had a busted input jack, it still worked, it just had the nut and part of the housing broken off. The customer was fine with me swapping the busted jack with the headphone jack because he never used the headphones.
Both jacks are identical stereo design (3 circuit) cliff jacks. I told him that I would order a new jack and he could drop it by sometime in the future and I would restore the headphone jack, for right now he needed the amp for some upcoming shows this weekend. I pulled the preamp board, swapped the jacks and stuffed it back together again. When I power up tested it I got not sound out of either channel... damn!!! why me and why now!
I figured I screwed something up so it came apart again but everything looks fine. I shot a signal into the input and I could see it plain as day at the preamp tube (12AX7) grids but this is where things get weird, there's no signal coming out of the tube or at least almost nothing. Before I continue here's a schematic of the input stages...
![Click image for larger version
The signal path comes off the cathodes of VT1 but I get nothing from there on. I checked the supplies and I get -78.5 volts on the cathode and somewhere around +64 volts on the anode... this should give me some output signal, right? well, it don't. I tried another 12AX7 and even an ECC83 but I get the same results. The tube has 12.6 volts on the heater and the tube lights up and gets warm, it's got to be O.K.
I fiddled around with this thing for a while but have not injected signal past this point to see if the rest of the preamp and power amps work but I'm pretty confident that they will, If I'm not getting signal through the first stage then the rest is just academic at this point.
Any ideas?
Any ideas?
