Hey guys,
My Deluxe Reverb is making some weird noises! I've never actually heard an oscillation before, but this is definitely an oscillation noise that kicks in once the volume gets high enough (either on the volume knob, or by really hammering the strings) and goes away when the input volume dies down again. It sounds like a buzz/fuzz note, louder and on top of the guitar itself. When trying to isolate the problem, I found that either disconnecting the reverb tank INPUT or removing the reverb tank driver tube the oscillation went away mostly.
I tried some different tubes, any 12AT7 caused the same problem. I had a 12AU7 lying around, and this did not cause any problems. I'm guessing because it is a way lower gain tube.
I tried moving the lead dress around with a chopstick and that didn't seem to do anything.
I tried changing reverb tanks and that seemed to work, going from an "A" 8 ohm input, the only other tank I had to try was a "B" 150 ohm input. This stopped the oscillation/noise/distortion. Interestingly, when I switched to the B tank, I heard a "popping" at high volume (10) and found it to be arcing between pins 5 and 6 (or 6 and 7 I forget).
When the oscillation was happening, I could see spikes with the oscilloscope on the speaker output, reverb driver input and even as far back as the volume knob and the grid of V1! But as soon as I pull the reverb driver tube, it doesn't happen. I'm at a loss, any ideas?
