I'm a little new to amp repair. But I'm trying to tackle an Apogee DA series. it seems similar to an older Crest - say a CA9. The channels come in 4 modules: a preamp module, and then 3 modules that make up the output stage. 1x -ve stage, 1x +ve stage & one that is connected in between both (but still involved on the output stage). I believe the pre-amp board works. I can use either one on my better channel & get the same result.
One channel is out of protect - but has distortion & low gain. (.6 amp on the kill-a-watt meter with this channel installed)
One channel is in protect with a +10V DC offset. (1.0 amps on the kill-a-watt meter)
I cannot find any shorts in the output. And this is where my experience ends. I'm not sure how to debug.
The output feeds back into the input - through what appears to be a differential circuit. So, I'm not familiar with how I debug where the initial offset is coming from - and what is simply a response from the differential circuit.
I attached the schematic. How do I start?
