Hi! I just finished my 1987 plexi 50w build, I checked all voltages and all seems to be right, except the bias voltage at pin 5 of power tubes, it´s high, -7.8v, when it shoud read around -40v, I checked the bias circuit and all is ok. Here´s the schem of the bias circuit:
I have installed a Lar/Mar type PPIMV, but again I checked everything and all looks correct. The thing I noticed is that I have 325v entering at the bias circuit, wich is fine, then 220v after the first resistor (220k), but then only -12v after de diode, is it normal?
