Hi there! got this GK MB200, is a ICEpower 200W class D amplifier (50ASX2) board. It has an AUX power (25vdc unreg) wich is regulated with a pair of 7815/7915 extrernal regulators, wich feeds the rest of the external circuits, Preamp, etc.
The unit was not 'turning on'. In fact it was turning on, but without the 7915 negative rail, i found R15 (10ohm) fuse resistor open at the input of the regulator.
Replace that resistor to see wht happens, and the -15V came back, the 'On/protect' (blue or red) led light up staying on for 5 sec. and then became blue and stars to smoothly blinking, then i realize U7 was getting very hot. I take the IC out and put a socket in place, the IC is not bad, but when i take it out of the circuit everything works fine. Im not understanding why the ic is getting hot, in fact i would like to understand what is that 'diode- optocoupler-jfet' arrangement arround U7....
