I couldn't get this amp to bias properly, been at it for a while.
After poking around tonight, I found that the PI plate voltage was randomly jumping (rising, holding then dropping) as well as spiking - both in the range of 25 to 50v. This circuit also feeds the screen grids (heavy watt resistors) of the output tubes.
The only thing in the circuit I see that might cause this is the bridge rectifier feeding the circuit (1n4007 diodes) so I thought I'll replace those and see.
Since I need to tear down the amp to get to them, I plan to replace them with the 3A 1000 PIV 1n5408 diodes since I have a bunch on hand.
I'll report back, just wondered if anyone else has seen this?
