Hey guys. I have a Valvestate vs65r that makes a static noise while it is on. The static is independent of the volume or any other controls. In fact, it even does it when nothing is plugged into the amp. It stays the same volume and although I can still play through it, it's very annoying since I would like to record with it soon.
The static noise started after I resoldered some things since it was popping at times. I also replaced the 4 large capacitors and the transistor at T4 because I thought I burnt it up.
If anyone knows what could cause this I would really like to know so I can fix it.
