Hi all. I removed the 2000pf suppressor caps from the output tubes of my ’72 Fender Bassman and now I’m getting oscillation when the amp is cranked. I know this is probably due to sloppy lead dress. I was going to just try a lower value (1000pf) but I would really like to implement something along the lines of the 5F6-A Bassman by using a 47pf across the plates of the phase inverter. The tweed Bassman uses a 12AX7 for the phase inverter where the silverface uses a 12AT7. Because the plate resistance of a 12AX7 is so much higher than the 12AT7 (62K vs. 11K), would this mean that I would need to use a much higher value cap than 47pf to get the desired effect? I was thinking somewhere around 250pf. Does this make sense or am I way off target? Thanks,
-Brian
-Brian
