Hey guys,
I had an Ampeg BA-115 (100 watt) blow both of it's output ICs and take out the mains fuse. I replaced the two ICs, IRFP-140R and IRFP-9140R, with an IRFP-240 and IRFP-9240. I powered the unit up and it worked, until I put a signal through, at which point it blew the fuse again. The FET gate resistor R49 reads 38 ohms instead of 47. I'm getting -25 at D of Q5 and -36 at S. Is my problem in the voltage mismatch?BA115_Schematic[1].pdf
