Ampeg Gemini II 2 - 7591 tubes red plating and what not
  • Ampeg Gemini II 2 - 7591 tubes red plating and what not
    This is the mid-60s version. All point to point (the control panel does not have a pcb either).
    Caps - all new, everywhere.
    Resistors - all check good.
    Transformers - check good.
    Power Supply - new diodes, caps, everything.
    Bias pot/cap/resistors check good. Cap polarity observed (+ going to ground)
    Here's the thing: It was working perfectly 100% (after the restoration)... then it started red plating. Bought some new JJ 7591 tubes and still red plated.
    PROBLEM:
    When I measure the B+ my DMM starts clicking profusely like a Geiger counter and I got 513v at A as well as at B. Then I got like 460v at F. Measurement was taken with tubes pulled out. At this time a bright small pinpoint spark appeared just above the rect. diodes and 220K resistor feeding off the HV leg. FWIW, I also measured about 20v B+ when in stand by mode.
    Control Grid (on standby/no B+) = -22v is the other measurement I got before turning it off.
    I really want to avoid turning it back on so... any ideas what could be wrong?
    Question:
    What is up with the .1 cap tying the heater center-tap to ground?
    Thanks!
    Your B+ will naturally run higher with the tubes removed.
    The cap to ground for the heater center tap is just a way of grounding the AC without a direct connection. Hum or ripple will flow through the cap.
    A small brighgt spark is an arc, and will have to be removed. A spark jumps between two places, and the plasma of the spark then acts as a conductor. It will carbonize the surface where it travels. Carbon is conductive, so every trace of that must be ground away. If it happens on a tube socket, it is usually easier to replace the socket. I use my Dremel for grinding away carbon.
    Two tubes red plating or just one?
      Both tubes red plating. Takes them about 5 seconds to start glowing.
      I don't see any carbon or trace of the spark. Resistor and diodes still test good... I'll replace them anyway.
        Problem solved!
        After moving some connections around it finally works now. One of the eyelets on the board was conducting from the eyelet next to it- The last filter cap and the anode of the bias diode were apparently conducting through the board material. I simply connected them to different eyelets.
        Thanks for responding Enzo.
