I have an XR-1200 that has developed a waterfall (lacking better descriptors) sound when I run A and B up. The more the mains are up channels are up the louder the sound. The amps run fine plugged in directly...bypassing the mixer and the eq. I re-did the voltage regulators (on the main board) and a diode about two years ago.
I need it working or I need it out of the shop...
Thank you,
Novo
P.S. Peavey said clean the input/output switching jacks...did that. Also tried unplugging connections between them and the main board....no luck.
Thank you,
Novo
