I replaced the PCB in a Laney AOR 50W amp, and have rewired the whole amp
This is not my first amp build, I am trying to troubleshoot the high voltage power supply.
I have tried swapping almost everything in the amp including subbing in a power transformer
but I am starting to wonder if how I am testing is invalid and would blow the fuse anyway.
I started removing things from the circuit to eliminate components..
Right now the amp has been reduced to a bridge rectifier, a HT fuse 1/2 amp
and 1 cap, that goes to ground, ( with no load on it)
Is this not a bomb? I mean can you troubleshoot like this or should you at least have
say a 220K resistor going to ground, I have not been able to keep that fuse from blowing
I have gone through too many fuses to count, would that cap just draw current and charge like mad
and blow the fuse anyway? ( I also tried a different cap to make sure the cap was not shorted)
I really would like to see the power supply work with minimal load on it and not blow the HT fuse..
What would be a good way to test this? The fuse is after the bridge and yes I have also swapped out the bridge
Sorry if I rambled I am trying to catch you guys up on this build, but right now the amp is not really involved
