Hi all,
Mate of mine has just dropped me off his faulty Marshall DSL100 head.
Had a quick check and the pre-amp looks to be ok (took send output to a seperate amp and the signal is fine). Just after taking the chassis out and found that both R6 and R9 (1R 1Watt) looked suspect as the paint looked to have peeled off these resistors (must have lit up). Meter checked proved both are O/C. I'm not up to speed on valve theory as I'm a TV repair guy. Both these resistors feed through to pin 7 (K) and pin 1 (G3) of the 4 power tubes. Any of you guys seen this fault before? Appreciate any checks you would suggest before I go diving in - something must have caused these boys to go high.
