After restoring my 44 yr old Traynor YBA-1A, full recap, revised grounding & power distribution, I first set it up with EL-34’s to get familiar with it after all these years. I added 1 ohm cathode resistors on the power tubes, grid stoppers & 1k 5W screen resistors, along with a bias pot, as it was fixed bias before.
I had measured the OT as having a turns ratio of 21.5:1, and a plate impedance of 3.8k +/- 10% from 40Hz-5kHz (3.5k @ 50Hz). Plate supply @ idle measured 570V, and 540 to 520V @ 50W/8 ohm load (20V p-p ripple). The output clips @ 20V RMS (50W/8 ohm) steady state.
I then added a 300V Screen Supply based on an old Grommes 260A Hi Fi Amp that used KT-88’s and a 6L6GB wired as a series regulator from the 2nd stage filter yielding 304VDC at the 1k grid resistors of the 6550 tubes that I used for this second iteration. Revised the bias circuit slightly to give adequate adjustment range, and started with 30mA plate current.
After finding (to no real surprise) I still only had 50W output steady state, I set up my burst sine generator to see what I get at 10% duty cycle, using 50Hz sine for 100mS, -30dB or -20dB signal for 900mS, with a 1 Sec rep rate. I was interested to see if there was greater power output during short burst, and to see what the power supply sag was under full power drive.
I could barely get 1dB over 20V RMS before the output was clipping. Looking at the PI stage and the plate circuits of the power tubes, I found both clipping at the same time. NFB around the output stage is 22.3:1 (100k FB, 4.7k shunt). Measuring across the 4.7k grid stopper resistors, as soon as the amp begins to clip, there’s voltage drop across them.
With a turns ratio of 21.5:1 on the OT, 20V RMS on the output would yield 430V RMS on the primary, plate-plate. Each tube would be supplying half that, or 215V RMS/304V peak. Looking at the voltage swing for each plate on the scope, I see a bit more than that (around 340V pk), though that may just be a reading error on the scope. Still, that’s well below the plate supply of say 520V at the low side of the 20V ripple seen under full power drive.
With the regulation of the power supply, and what looks like a PT made for 100W amplifier operation, I surely have sufficient supply reserves to go well beyond this 50W limitation I’m facing.
Is it the OT’s primary impedance that is too low for 6550/KT88’s? Is it the NFB circuit restricting the max drive? Is it the LTPI circuit configuration within the loop?
