Korg M50 Keyboard
  • Korg M50 Keyboard
    I had this keyboard for repair and did some probing on the forum..Somebody mentioned about having to replace a couple of SMD caps....I contacted the Canadian rep and sure enough....C37 and C153....47uf/10V low esr....on the main board...the one with the sd card slot.....one cap goes on one side of the board and the other cap goes on the other side.....however, some boards, like the one that I had only used one of these capacitors....these are to solve lock-up issues and error messages such as "left Panel Loading" or "Right Panel Loading"....apparently this is common for the M50 with a 61 keybed....Just thought I would post this so that it helps somebody out in the future....
    Cheers,
    Bernie
