I have a Peavey Mark III on the bench that is driving me batty.
The low side predriver, Q7 emitter resistor (R32) gets real hot & then burns Only when a load is applied to the output.
All resistor paths have been verified.
All the transistors on the output are new.
No transistor (removed from board) checks as bad.
The idle voltages all agree with the schematic.
Main rails & the 15 volt rails are steady & ripple free.
The output voltage is in the millivolts.
I have subbed in a new TL074 & even removed U3.
The output looks perfect without a load.
When a load is applied , the bottom half of the sine wave collapses (@4 vAC output).
Then R32 bakes.
Any insights on what I am missing would be greatly appreciated.
I tried calling Peavey but I think they are on vacation.
http://music-electronics-forum.com/a...ian_mk_iii.pdf
Then R32 bakes.
