I've hit a wall with a vintage (1965) Fender Pro Reverb amp, and am hoping some of the more experienced vintage Fender gurus here can validate my findings or point out anything I may have missed.
The amp came to me with bad power tubes / blown fuse, and after opening it up I discovered the plate resistors were shot. Most puzzling was that 99% of the components on the board had been replaced -- not a great job, but decent enough. Asian poly caps, carbon film resistors. The optocoupler was still original, as was the wire. Some mods had been done (splitting shared cathode caps / resistors on a couple of tubes) and some of the values used elsewhere deviated from the schematic. I replaced these values with correct values, removing mods as I went.
After I was finished, I fired it up and there was a lot of 'blow,' or noise, with the volume turned down. Sounded similar to bad plate resistors, but I'd actually replaced those during this process. In my troubleshooting, I isolated the noise to the Reverb channel / ch 2, noting that if it was disconnected the amp was dead quiet. After some preamp tube pulling, I then isolated the noise to V4, the reverb recovery / 2nd gain stage for ch 2. I then checked the Reverb transformer, grid / grounds and determined it was happening in the other triode, the pin 6-7-8 side. After replacing all parts associated with that triode (including the resistors and bypass cap) the problem was still there, and I figured it had to be the grid wire or perhaps the socket. I disconnected the wire and ran another wire and the noise remained, so I changed the socket. The noise remained. It's the occasional low-level electrical noise, followed by some scratchiness that was intermittent. Not insanely bad, but it's louder than it should be and fairly annoying at times. At this point I lifted and subbed components in for the stuff I'd replaced, checked all the pots again, checked grounds, etc. The only thing that killed the noise was disconnecting ch 2 directly at the 220k PI blend resistor or lifting a leg on the .1 cap that preceded it (I subbed in another cap to test, no change).
After getting some voltage readings on a batch of lifted capacitors that were still attached to the board, I started poking around, and here's where I'm at. I've heard the arguments about conductive boards being a myth, but I wanted to share my findings. I'm measuring almost half a volt DC at certain parts of the board -- I've confirmed this by lifting the B+ node that feeds the plates and confirming there's no voltage reading after that. The highest reading I'm getting is the area around where the plate B+ feeds in, and this happens to be very close to the reverb recovery resistors.
Now I'm starting to see why every component on this board had been changed.
The amp had previously had a full doghouse cap job as well (Sprague Atoms) and although I've tested them (all test fine) and the voltages are right, I have not replaced all the new caps. PT seems fine, voltages are steady and where they should be for 120vac at the wall. Choke checks out as well. So a complete fiberboard replacement might be the final frontier here, other than subbing in a new OT. I also don't think this is the issue because as I mentioned, ch 1 sounds great so long as channel 2 is disconnected.
Is there anything that sticks out here as something I may have missed? I'm really open to suggestions at this point. I had to leave it and get some distance for a bit, as I'm really scratching the ol' head here. Many thanks.
