When I had my Traynor 1970-vintage YBA-1A Mk II Bassmaster Amp up and running last month, and plugged in the shop bass I have here for checking out amps I service, it brought back my original feelings about it's tonal range from the early 70's. It lacked tonal range. Cranking bass up to 10, I'm still wanting to twist the knob off. That's after re-capping the amp, stock values in the tone stack, though using Sprague 715P Series Metallized Polypropylene.
This morning, needing to write up a tutorial for a colleague of mine in using the Amber 3501a Audio Analyzer in cahoots with the Velleman PCSGU250 Scope/Generator/Bode Plotter system, I first set it up atop the Traynor to run some response plots of it's 'stock' Tone Stack. It showed pretty much the same as I saw when I loaded the tone circuit into National Instruments Multisim spice program a couple weeks ago. I knew after hearing this amp again last month that the stock tone circuits would be short lived, though I haven't made any firm decisions what I would use.
Here's the results. My 'baseline' plot on all 5 sets of curves was setting all four tone controls to mid-position, then run a min/max set for the Bass Control, the Treble Control, the LF Range Extender (Midrange) Control & the HF Range Extender (Presence) Control. Then, a set of curves setting Bass to Max CW/Treble to Min CCW, then Bass to Min CCW/Treble to Max CW. I see why it has always left me wanting more.
As you can see from the response plots, you're lucky to get 10dB adjustment range on the Bass control, without having to drop the Treble control for a bit more. The Treble Control has the greatest range of adjustment, though it too isn't very impressive. The tonal range of the Traynor YBA-1 (one version of it, at least) looked a lot more intriguing than this, though lots more parts. Might go the direction of the Ampeg B15R, as I do like the sounds I get out of those amps. Midrange & Presence control adjustment range just don't yield much. I know this amp is patterned after the '59 Fender Bassman Amp. Is it really this limited?
The test setup uses the Velleman PCSGU250 as the Closed-Loop Response Analyzer, it's Sweeping Generator's output connected to a HP 353A Output Transformer/Step Attenuator for Balanced Output, the output of the Traynor connected to an Amber 3501a Audio Analyzer, used as a balanced conditioning amp ahead of the Velleman Scope Input, output taken from the Distortion Analyzer BNC. Amber 3501a's BW was set to 80kHz (3-pole LPF), and loaded with 16 ohm resistive load. Output monitored on a Tektronix 7633 100MHz 4-trace scope (7A18A plug-ins).
