Hi
I have this amp for repair. Its a purple stripe. No Graphic EQ, and non- simul-class. It has 2x 6L6's.
Cleaned it up, re-valved it, clean controls, etc...
Lead channel wasn't working, found an open-circuit 470 ohm res in the LDR led drive circuit. Now works like a charm.
Only one problem.
The amp now has a hum when turning up the master volume. If i engage the lead channel pull switch, it goes away.
If I plug a signal into the return socket and turn up Master Vol, its gone and clean.
I have narrowed it down to Valve V3 section. Before V3 no hum. After V3 where it goes into V2 again, on the Pin 1 of V2, I get this annoying loud hum.
FYI, I used a signal tracer amp to check this.
I'm not hearing it on V3 plates, but this might just be that there isn't much gain there?
I have checked all the filter caps for ESR and Capacitance. All check fine.
In the schematic they use 1k resistors between the B, C, D supply points. I even went so far as to replace the first 1k with a 5k6 as in the mark 2 schematic. Doesn't really make a difference. That tells me the fault isn't in the power supply; I hope...
Another thing I forgot to mention, is that this amp has the reverb tank removed. I tried shorting-out the RCA in/outs to the tank, but no difference.
I played around with different valves in position V2 & V3 still no difference.
Thoughts??
Only one problem.
Thoughts??
