hey guys,
A friend of a friend brought me an Ibanez toneblaster 50R. He says it has a "weird echo and doesn't have as much power". I guess it only does this on occasion. I took it home with me and played through it. I had a heck of a time hearing anything wrong with it. Its a SS amp and it sounded like one. Like many SS amps it has a lot of distortion on the hot channel. But when the distortion decays it makes a crackly sound, it has ALOT of feedback. I don't know what he means by the echo noise? It has a crappy spring reverb but there isn't anything wrong with it. I considered the fact that he could have something in his band environment that could have caused the echo noise. I used to have a pv bandit 112 transtube and as far as volume goes the pv was much louder (sounded alot better too).
I started troubleshooting by plugging it into my Marshall 4x12 cab. Sure it was a little louder and fuller but not as loud as I think it should be. I opened it up and everything looked fine ( I hate when things aren't obvious). I let it power up for a while nothing was too hot. The first thing that comes to mind when I think of some of the symptoms are xsistors and it looks like fets are used also. I am more of a tube guy but I don't like limiting myself. It uses 4558 ics and i tested pins 2 and 7 on all of them and they came through fine. no resistors out of tolerance. Diodes were fine. 1uf Jun Fu electrolytics throughout. they look pretty cheap (not a straight looking radial shape). I'm not up to snuff when it comes to testing fets and power transistors. On my stuff I use the shotgun approach on transistors and electrolytics and it has done well for me. but I should trouble shoot them if I'm not the one paying for it. Uses Mospec tip42c & 41c, tip32c &31c, and Toshiba A1941 & C1598. Any suggestions would be appreciated.
