The only references I could find for this amp were to a different version that had 2 12AX7s in the upper control portion. This amp does not have those, so before someone links that stuff, that ain't it. This came to me with the wrong tubes installed in at least some slots, but I can't find any reference to what is correct. I'd rather not reverse engineer the entire amp so I'm hoping someone has the answer. This amp is from the early 50s and uses a field coil speaker. Here's what I do know:
V7: 5Y3. All tests were done with this installed, no other tubes.
V6: Standard Octal power tube by the pin out. The other version used a 6L6, this showed up with a 6V6 in this slot and the one next to it (wrong for sure on V5). 6V6 might be correct, or 6L6. Pin 1 is used as a connector tab.
V5: This had a 6V6 in it, which would have grounded the B+. By the pin out, it should have been a 6SJ7. This one I'm pretty sure about (gnd heater gnd grid gnd G2 heater plate).
V4: Standard Octal power tube pin out, but pin 7/8/1 are grounded together. Showed up with a 6Y6 in this slot, which is fine for the pin out, but correct?
V3: Same as above. Showed up with a 12SJ7 here, definitely not correct.
V2: Std. 9 pin 12AX7 type with common cathode EXCEPT: No connection at pin 9 so the heater is not center tapped, heater is connected to pin 5, there is a -90VDC on pin 4.
V1: same as above except no bias voltage on pin 4. This looks like it was set up as a cathode follower to drive some of the controls.
12AX7 type wouldn't work AFAIK in V1/2 due to the 6v heaters no center tap/no parallel.
Thoughts?
Thoughts?
