Fender Stage 1000 with a foot switching issue. The reverb switch turns on and off the digital effects as does the effects switch. All other functions on the amp are normal. Without the foot switch plugged in both DSP and Reverb function normally. Following the schematic test points, I have these results. TP 40, 9.27 volts with eff off, reverb on (should be 4.99V)
9.27 volts with both on. ( should be 7.45)
TP 44, 5.74v with efx off, rvb on (should be 6.41)
5.74v with efx on, rvb on (correct voltage)
All other voltages normal at test points.
Stage 1000 - 1600.pdf
