I built one of those "wall droppers" that you find a diagram for on RG Keen's website.
I probably only use it 1-2 times a year...but when I do, I find that 12 Volts is too much.
So, for 6 Volts.....
If I just use one end of the secondary and the CT, does the tranny still maintain its 3A current rating.? I assume it does.
But I just want to make sure I do not need to parallel the 2 tranny ends, and then use the CT as the "second" wire...if you know what I mean.
Thank You
Thank You
