A friend of the family stopped by today looking for help with a few amps he picked up real cheap. One was an Ampeg hybrid with a bad static noise which I diagnosed as input jack problem. I pulled the chassis, removed several screws, a few harnesses, countless knobs and nuts from pcb mounted pots and lifted the pcb so I could reflow the connections at the board. I also cleaned the contacts with contact cleaner. I put it all back together & fired it up and it was good as new.
The second was a Peavey 6505 that you can hear powering up when you turn on the power switch but the tubes remain dark. I first checked the fuse but that was good. I thought maybe it was a faulty tube given that I have heard Peavey connects the filaments in series. I pulled them and tested all. I found one very weak but working 12AX7 which I replaced so nothing there. The power tubes are all beat and boarderline working so that wasn't it. I checked all of the board mounted fuses and they are all good. I probed a little deeper and started looking for fried components and discovered evidence of an overheating situation on a plug that mates with a header on the power tube board (see the connection at J11).
![](http://i706.photobucket.com/albums/ww70/2266vm/6505HARNESS_zps751701d4.jpg)
![](http://i706.photobucket.com/albums/ww70/2266vm/j11closeup_zps43aada20.jpg)
That pin must have gotten hot and the burn distorted the housing so the pin may not be mating with the contact anymore. The board itself doesn't appear to be damaged. Should I just try replacing the harness or is this likely symptomatic of something other than a tube going belly up?
