Hot Rod Mayhem!!!
    I am fairly certain now it's the IC. If I decide to order it, I have to wait a week for it as well as the new switch.
    Which gives me some time to think about why it stopped working.
    These things are pretty delicate.
      Found a switch. Replaced the chip in a socket.
      Test voltages still out of whack.
      I decided to check the diodes in this circuit and found D23 is open.
        That would sure throw the measurements off. Please post your results after you replace D23.
          I've decided to take the amp to a tech. This is work is beyond my skill level. For now.
          My thanks to everyone.
            I just came across this thread. We saw a similar problem a while back. One of the relays was stuck internally allowing the master volume to be active in the clean channel setting.
            Drewline
            When was the last time you did something for the first time?
              Guys thanks for everything. I wanted to let you know that my hot rod is all fixed and working like new.
              But better because everything works. When I first bought it, it was sold new to me by a music store but right there on the showroom floor it didn't switch properly.
              Then, it kicked in. Looking back, I should not have bought it as I suspect now it was a return. Maybe.
              I took it to a tech and he installed a brand new pcb at a very reasonable price. It is now operating at 100%.
              If something goes sideways with it from here on out, I'll take it to a pro.
              in the meantime, I'm going to practice on scrapped out pcbs to get my soldering chops up to par.... Thanks
