While going thru our rental inventory's stash of Vox AC30-6/TB combo amps, I came upon one with a solid state Groove Tube rectifier module installed in place of the 5AR4. During the preventative maintenance work on these, I was correcting the wiring on the rectifier's output, where the factory had wired the HT load off pin 2 (heater) instead of Pin 8, being the other side of the heater coil AND the cathode. And I've removed the switched plate leads to the rectifier, that have been the Standby function, spliced each together, and instead, open up the power tube's cathode circuit (summed cathode buss to the cathode resistor/cap network) for the Standby function.
Not wanting to have the SS rectifier module in place, putting HT onto the plates of all the preamp tubes before they've warmed up, I went to install a 5AR4. Hm.... no hold-down clamp.
Pulled the chassis from the cabinet, and found besides there being no clamp for the 5AR4, one of the EL84 tubes was missing it's spring-wire hold-down clamp. Figures I ran out of those and hadn't ordered more.
After ordering those, and not being able to find any 6V6/5AR4-sized hold-down clamps...resorting to the bear-trap clamps for the time being, I thought about the EL-84.
Grabbed a bottle cap from an empty lemonade bottle, punched a hole in the center & two on the sides with a Whitney punch, fetched my stash of 3/32" dia shock cord (for restoring condenser microphone shock mounts' elastic suspensions cords), some aluminum ferrules and a paper clip, and fashioned a temporary hold-down clamp:
Hate having to leave an amp in pieces waiting for parts. Should do the trick for the time being. The white thingies on the 5AR4 clamp hat is silicon rubber tubing, that I've taken to use on the clamp hats these days, having tired of replacing tubes that end up with fracture holes from contact with the hold-down springs, driven by vibration in the tour trucks.
I didn't use them on that flange that mates up with the spring on each side of the clamp hat.....that spring/flange mating has normally been in direct contact with the straight-body 6550 tubes (see photos below, and has caused fractures of the glass bottle, as seen in the following photo, Then, photo of the cushioned clamp on some KT-88's, which have the tapered top shape to the bottle.
