This is a high end all tube Hi fi stereo amplifier, with 4 X el34s, 2 X 5u4s and 4 X 6SN7s. There are many rectifiers. There's a bridge rectifier connected to the 2 5u4s.
I have no schematic. If anyone has one please post it. I've tried contacting the company in Australia and the representative in Ca and no luck.
There are a couple of problems with it.
It came to me earlier this year and many tubes had gone bad and one el34 socket was burnt, which I replaced. I also found one shorted rectifier diode(1504?) in the bias circuit.
Anyway, I replaced the quad and the 2 5u4s and the diode and had it running .
Now a couple weeks ago the owner tells me the fuse blew as soon as he got it home months ago but didn't call me back until now.
This time around I found that the first main rectifier was measuring some strange resistances so I changed it out and the unit starts up. However after some time with the caps drained I tried switching it on without a limiter and the fuse blows. So I order up a KBU 1010 rectifier and it starts with the limiter but blows the fuse without it.
The mains fuse on the IEC connector says it is suppose to be an F3A but I only have T3A fuses and they are blowing.
I just tried a T4A fuse and it starts up without the limiter the last couple of times. I did this thinking the fuse is not rated high enough. I know should just calculate the fuse rating myself but I thought I'd would ask here first.
Any ideas on the fuse rating? Or for that matter what other issues could be causing the fuses to blow.
The other issue is with the volume pot on the bottom right of the picture. It got damaged in transport and needs replacing or repair. Any suggestions on what this might use. It is a stepped pot. I see several on ebay that are similar looking and are about 100K, is this about right for a replacement?
Thanks for reading and thanks any ideas in advance.
