Hi, first time poster here
I recently picked up a Peavey Envoy to leave in the car as a emergency backup at gigs,
It has a few issues:
1. It has no reverb
2. When playing on the clean channel it momentarily drops out if you hit a chord hard, it's fine if strumming
3. The drive channel sounds like a quiet can of angry bees, when you switch over it starts off normal but drops in volume within half a second
Things I've tried/found out:
1. Removed & cleaned reverb tank connectors - no fix
2. Tried known working reverb tank - still no reverb
3. When reverb is bypassed with foot switch the drive channel operates normally, but has the same issue of volume cut out as channel 1.
Thoughts?
Thanks,
Brad
1. It has no reverb
Thoughts?
Thanks,
Brad
