Hi
I have a Fender Acoustasonic SFX that has a couple issues. It came to me with the complaint that the amp was "buzzy". A quick look and listen determined that the 8" upper speaker was blown. I verified this by swapping in a known good speaker.
While doing the speaker swaps it became evident that the 10" bottom speaker has very low output. Swapped in place of the 8" speaker it seems to have the appropriate volume, so it seems that the issue with the 10" speaker is the circuit supplying it, not the speaker itself.
I am curious as to what could cause the speaker to not have the expected output, any ideas?
I have the schematic and started to look at test points. Unfortunately I don't have a signal generator and so couldn't follow the print's instruction on how to test past Test Point 7. The results I did get for some of the test points seem weird though..
TP1 and TP2 are at the rectifier diodes. The schematic says 20.2VAC, I measured 39.5VAC
TP3 and TP4 should be +28.4VDC and -28.4VDC respectively. I measured +52 and -52VDC.
TP5 expects +15.6VDC and I measured -15.8VDC. I wonder if there is a typo on the schematic?
TP6 measured good at -10.3VDC TP7 measured good at -43.7
Hope someone can suggest some areas to look at to fix these issues, which (to review) are low output from one speaker and possibly strange voltage readings.
Thanks in advance for the help!
Acoustasonic_SFX_schematic.pdf
