Just finished assembling this project and am experiencing some trouble getting it to fire up. This is my first attempt at anything amp related, i've done about a dozen stompbox projects up to this point and trying to get my feet wet with building amps. I've gone over the layout and double checked my work, I'm a little unsure if i have certain components mounted properly because ive never used strip terminals. As of right now, i'm not getting any sort of signal or sound when its turned on. The red indicator light does turn on though.
Here is a schematic: http://www.modkitsdiy.com/sites/modk...chematic_0.pdf
Here is the layout: http://www.modkitsdiy.com/sites/modk...drawings_0.pdf
Using the troubleshooting guide from the MOD kits website (here: http://www.modkitsdiy.com/sites/modk...supplement.pdf) I took some voltages on the suggested test points and here's what I wound up with.
HV: 286 VDC
B1: 286 VDC
B2: 280 VDC
Power Tube Electrodes
Pin 7 286 VDC
Pin 9 0 VDC
Pin 2 0 VDC
Pin 3 0VDC
Preamp Tube Electrodes:
Pin 1 255 VDC
all other pins measuring 0VDC
Lastly here are some pictures of the inside of the chassis.
![](http://i1092.photobucket.com/albums/i412/southofadam/image4.jpeg)
![](http://i1092.photobucket.com/albums/i412/southofadam/image2-1.jpeg)
![](http://i1092.photobucket.com/albums/i412/southofadam/image1-2.jpeg)
Any and all feedback is appreciated, I can post more photos if need be. Thanks!
HV: 286 VDC
B1: 286 VDC
B2: 280 VDC
Pin 7 286 VDC
Pin 9 0 VDC
Pin 2 0 VDC
Pin 3 0VDC
Pin 1 255 VDC
