This is a late 70's design, Harry Joyce wired 50 watter with v2 cascaded for higher gain.
And that is where the noise is coming from.
Once the master is up past half way the noise becomes too much.
Remove v2 and its fine.moving the shielded input to v2 helped but I can't imagine this much hum is normal on these (around 400mv with pre amp pots turned down)
I'll try and find the correct schem and post it, there are so many weird versions with no documentation.
