Orange tranny color codes?
  • Orange tranny color codes?
    Anyone know where I can find color codes for an Orange GRO100 power trans?
    Voltages are low when using the 115v tap, and just right with the 200v position.
    It looks like some of the wires were soldered after the factory.
    May I suggest that you contact Orange directly?
    I have had nothing but good dealings with there tech support.
    Link:
    Orange USA
    2065 Peachtree Industrial Court
    Suite 208
    Atlanta, GA
    30341
    USA
    Tel: 1-404-303-8196
    Fax: 1-404-303-7176
    info@orangeusa.com
      It should be exactly the opposite.
      Assuming you plug both settings in the same wall outlet.
        Yeah, it looks like the 115 and 200 volt taps were reversed on the switch.
        It just came from Germany (got damaged in shipping) so the German owner probably never noticed.
        It sounds cool running lower voltage from the 200 volt tap, kind of a "brown sound" going on, wink wink.
        casibom betturkey
