Howdy
I have an Orange AD30TC combo that is making some weird sounds when tapped or struck...kinda like a static/sizzle sound. Sometimes I can hear it on top of the notes when playing, and occasionally I can hear whistle/squeal sounds that start and stop intermittently when the amp is on.
I have had the main circuit board out of this amp (no small task, lotsa wires running over the board...) and have run a hot iron over all solder points. Even after that, when I tap the main circuit board I get that static/sizzle sound, or also when I tap any tube (all tube sockets are soldered to the main board). I have sprayed and retensioned all tube sockets - twice.
I have the schematics for the main board and have tested all of the DC voltages. They are all about 5% low, but are consistent.
Anyone have similar experiences with an amp? Is it a question of me not finding the bad solder joint or component...or could it be that the filter caps need to be changed?
OrangeAD30TC Main Board P1.pdf
OrangeAD30TC Main Board P2.pdf
Thanks In Advance!
Thanks In Advance!
