I've got a mid 70's silver face twin. Master volume pull switch model. Not the ultra linear model.
Anyway, it makes a crackling static noise all the time, even when not playing. It doesn't seem to affect the regular sound of the amp, as in it's not distorting when I play, it's just an additional sound that can be pretty annoying depending on how loud or quiet it decides to be at any given moment.
Turning all controls to zero does not affect the problem. I've pulled v1 through v6 one at a time and the crackling is always there. I've pulled out the inner and then the outer pair of power tubes and the crackling is still there. I just recently replaced most of the capacitors in the amp (all the electrolytics and what I guess are the coupling caps) but this problem was there before so it's probably not anything I did wrong.
I'm guessing whatever the source of the problem is, it's later on in the circuit, but I really don't know for sure. I tried re-soldering most of the points on the component board, but not much anywhere else.
Hopefully someone has some good advice that will steer me in the right direction.
Thanks!
Jim
Edit: Here's a link to a sound clip... crackling.mp3
Thanks!
Jim
