Bassman Plate Voltages
  • Bassman Plate Voltages
    Hi folks. Thought I would start a new thread as I am working through all the issues with this AA864 Bassman
    Schematic:
    http://vintagefenderamprepair.com/wp...-schematic.pdf
    Layout:
    http://vintagefenderamprepair.com/wp...864-layout.pdf
    Got the green/black OT wiring completed to the speaker jacks and powered up to test bias and vP. On the first power tube (far left looking at back) I am getting plate voltage of 345 and 0 volts bias current. The other power tube I am getting 440 vP and -12 m/a bias current using a bias-rite probe (tested and it works fine with other amp).
    I tried another set of good matched tubes with the same result so the problem lies in the first tube circuitry.
    Inside the chassis I am getting 450vDC to ground on both pin 3 sockets.
    -50vDC of the middle leg of bias pot
    -36v on both pin 5 sockets
    Not sure why vP and bias current readings are all out of whack with the bias probe between the 2 tubes? Help appreciated.
    Where exactly are you measuring the 345Vp ? In some part of the bias probe? If so swap them and see if the problem stays with that probe.
    edit: I see you said the probe worked fine in another amp. Then it sounds like you may have a bad socket or loose socket contact.
      OK not sure why but there are a couple resistors to ground from pin 8 on each power tube. The lower vP pin reads 30v and the other one reads 0v (which it should be)
      Should I just remove these resistors and tie pin 8 direct to ground per schematic or should I change the bad one that is allowing 30v to pin 8?
      Jeez this amp
        What value are the resistors? Some of the SF amps had them, or someone may have installed them for checking bias.
        If they are 1 ohm, I would suggest you replace the bad one. If they are something else, what are they?
        For time being yes you can just tie the cathodes to ground.
          Thanks. They are 1 ohm 2w resistors. They appear to be added on. I went ahead and tied the cathodes to ground per the schematic and all is well with the voltages. Thanks for the help
            Then they are an add-on for measuring bias. With them in place, you can measure DC mV across them and it will tell you what the current is in mA.
            A good question would be why the one burnt. Possibly a bad (or intermittently shorting) power tube.
              That is exactly what happened. a power tube shorted to ground via some wild solder job someone did at some point. all is well now. thanks again everyone for the assistance.
