I have a client's Mesa Dual Rectifier 3-Ch Solo Amp head on the bench. It came in due to Low Power Output, though I didn't find that to be true (91W Out @ 8 ohms, visible clip), but after listening to the amp and trying to sort out some really nasty noise when the Effects Loop is IN AND the Send Level set to "Normal", I had to step back and set up equal gain on the 3 channels (measured at the Effects Send jack), and got what looked like respectable noise measurements from all 3 channels (-60 to -70dBV wideband lower A-wtd)....Ch 1, having only 3 tube stages was the quietest, with Ch 2 & Ch 3, having 3 additional tube stages were a good 10dB noisier.
When I went to listen to it thru my 4 ohm test speaker (Ampeg BXT-115-L4), it was obnoxiously noisy, not making any sense with the measured data.
And, having earlier been running the amp with just the outer pair of power tubes installed and the two 5U4GB rectifier tubes out, I restored the 4 6L6GC's and the pair of rectifier tubes. Turning down the Effects send got rid of the noise, but also the overall gain. Bypassed the Effects Loop, now quieter, but lower gain. After plugging my bass in and listening to Ch 1, it was just downright strange, no LF definition, distorted, just odd. When I stopped playing, I became aware of a low freq pitch from the speaker, NOT HUM or AC mains related
I unplugged the bass, remaining in Ch 1. Still hearing some very low freq sound. Switched back to Standby, then back on again. Within a few seconds that Low Freq sound was back, like on the verge of motorboating. I switched to the Tube Rectifier mode, and the LF sound quit. Switched back to SS Rectifier, and within a few seconds, it came back. I haven't yet checked to see if it's on all 3 channels, and dependent on the Gain & Master Volume settings. I had to leave to catch my bus back home, but did find a post on this forum from another member having found this problem on a Triple Rectifier Solo head, and after changing the rectifier tubes, the problem went away.
The Cathodes of the two 5U4GB's are connected to the 1N4007 rectifier diodes, all feeding the 1st stacked filter stage ahead of the Standby Switch. Switching between the two rectifier modes is connecting the HV Secondary leads to either the diodes or the Anodes of the tube rectifier's, while the 5VAC winding is connected to the heater/cathodes of the tube rectifiers (and to the first filter stage).
I don't recall coming across this one before, and I only found one thread on it, describing the sound to that of a big truck coming down a nearby alley, hearing that low frequency rumble. I don't yet know if this LF oscillation is also related to the rest of the system noise. I'll resume tomorrow to see what's what.
Didn't find anything obvious on the PCB's, removed the rear panel connector board for inspection, no solder fractures on it or what is exposed fro the open chassis. Reseated ribbon connectors, but haven't tried to tear apart the amp. I did swap the one pair of 5U4GB's with another pair, though not brand new. Still had the LF oscillation.
How does this LF oscillation couple into the amp? Is this a common known problem, or do I have an oddball here?
